I have 3 snap dragon C-1 slalom skirts that generally will fit most any pre-2004 slalom boat and could probably be stretched onto a larger cockpit of the newer boats but it would be tight. Here's what I have
1. $35 Blue Neoprene with Bib Top - best shape of the three - needs new elastic suspenders - water tight - Size M
2. $30 Red Hypalon with Bib Top - next best shape - a couple of small aqua seal repairs to tube - one small area where inside cloth has delamenated from hypalon - small bit of mold on underside - water tight - Size L
3. $25 Gray Hypalon with Bib Top - shows most wear and age of the three - one small area of aqua seal repair to tube seam - underside shows lots of wear - water tight - Size M
The hypalon skirts were quite a bit more expensive than the neoprene skirts back in the day as they dont absorb much water since they are a rubberized type material.
Im located in Florence, AL but will ship to you. Probably $5-10 USPS depending on where its going.
Seems to me these tubes ran a little small so you might need to assume they are one size down.
See pics and email me with more questions. If you want all three I'll give you a deal.
email me: chrissoileauatyahoodotcom if you're interested.
Chris
For Sale - Snapdragon C-1 Skirts
Re: For Sale - Snapdragon C-1 Skirts
3/1/2013 - ALL SOLD - Thanks!!
