FOAM WANTED
VikingMatt
FOAM WANTED
Post by VikingMatt »
Anyone know where I can get hold of foam, needed for a c1 conversion? Most of the kayak shops sell it, but at much inflated prices. Are there cheaper alternatives? Living in Europe.
chuck naill
foam
Post by chuck naill »
http://www.kayakoutfitting.com/
THis is a good resource. If you have access to worn out boats you might consider harvesting the foam inside for your project.
Chuck
Guest
Post by Guest »
Minicell is always expensive. It is the nature of the beast. Those paddling shop prices may not be as inflated as you think!
Ethafoam is reasonable alternative at a much cheaper price. Except for knee pads, it works almost as well as minicell.
Another excellent source for foam in the US is John Sweet:
http://johnrsweet.com/index.html
But, considering the small amount of foam needed for a single conversion (less than a bun), buying locally will not be much more expensive than dealing with a US supplier. Good luck.
Jan_dettmer
Post by Jan_dettmer »
Here in Canada, we buy it from an industrial supplier.
It is about 125 EUR for 3 inch 32 sqft.
I think that is cheap. Buy a whole sheet and use it with other C-1
friends...
Cheers, Jan
http://www.bc-ww.com
Marko
Idea,
Post by Marko »
Maybe an drakkar seat system will help you with your conversion problems..
marko
www.drakkarkayaks.com
Guest
Post by Guest »
So what is the name and contact information of the Canadian industrial supplier?
Jan_dettmer
ALLFOAM INDUSTRIES Richmond, BC
604-277-7710
If you buy, ask them to cut the skins off!
Cheers, Jan
Guest
Post by Guest »
Thanks for the contact data!
