royalex repair needed knoxville tn
bgriffith
Post by bgriffith »
have deep scraped areas in vinyl in an old dagger legend. suggestions for repair of the scratches and gunwales in the knoxville area?
milkman
Re: royalex repair needed knoxville tn
Post by milkman »
Have any photos of what you want to repair?
For gouges and scrapes in the vinyl layer, I just clean with 99% rubbing alcohol and then fill/cover with G/flex. The goal is simply to protect the ABS layer with a layer of something. G/flex holds really well, is clear, and takes a beating. I used to use JB Weld, which also works well, but makes grey splotches all over your hull wherever you patch it.
PC-7 works really well, too.
