i'm a beginner c1'er and trying to decide what boat to convert.
i'm 5'11" and 225lb
money not that inportant but would consider used
looking for a river runner / playboat
something to due a stretch of river and then play
also any instructional info availble for c1'ing
so many boats to choose
thanks for any help
john c.
cincy.ohio
C1 selection help please......
- ghetto johnny
Hmmm
It depends on what you want in a playboat...
Surf, speed, stern squirt? Look around for a used full-cut Viper
Cartwheel and play in holes, and less concerned about speed? I'd seriously consider a Big Boy (larger version of the wheelboy). I've been VERY impressed with the Wheelboy, though my main squeeze is any one of my 10'+ squirt boats (pun intended ). The Viper (used, or new, but if you're spending that kind of $$ I'd definitely try one first...there are a few Vipers near you as i recall, and hopefully a few showing up at the Armada .)
There are also numerous conversion options, though I'd stick with a true C1 (surprise, surprise, I know).
At your weight I suspect an Atom may be a little squirrelly-others can speak to this better than I.
Playboat
Adam might be right about wheelboy.
I'm getting old and fat and at my weight 170 lbs and Wheelboy is quite perfect for big playwaves. I tihnk you will love the fatboy since it is most stable and easy to paddle.
Wheelboy will give oyu also awe performance on flat but might be bit hard for you on rivers at 225 lbs...
Marko
Marko
