Is the Taureau a planning hull or displacement???
the great gonzo
Post by the great gonzo »
Geoff,
don't know if anyone has a Taureau demoboat inSouthern Ontario right now, but Jeff from boatwerks told me that he will have one up at the shop in Minden next season.
Wendy
Weight range for Taureau
Post by Wendy »
Louie, What is the upper range on weight?
chris mack
Planing Hull?????
Post by chris mack »
Geoff you might want to contact Al, he had his at the gull last wknd.
Ok it spins and surfs good, how about vertical moves with those big ends?
Can anybody compare with Superfly?
keez
Post by keez »
Thanks Chris, I'll give Al a try, otherwise looks like I'll have to wait until Boatwerks gets one in.
Regarding doing vertical moves, probably easier than in my Nitro!
Geoff
Louie
Andrew Westwood has one in that part of Canada
Post by Louie »
Dooley must weight in at over 2oo lbs and it works well for him.
Al Greve
Post by Al Greve »
Hi keez, if you want to give my boat a spin your more than welcome. I`ll be at the Moose next weekend if your interested, I`ll be with Joe Langman and Paul Mason and they`ll both have Taureaus as well and I`m sure you could also jump into one of theirs. If that doesn`t work for you just email me and we should be able to set something up.
I was able to put the end down for some air at Centre Slot on the Ottawa two weeks ago...... It also owns Push Bottom, it almost wanted to go into auto pilot !!! Also had the driest run down McKoys ever...... only a 1/2" H2O after Baby Face. So it should be a blast on the Moose, Grass and Independence.
Al
keez
Post by keez »
Al,
How was Moosefest?
Thanks for the offer on trying your Taureau. I'd like to test the boat on something more local and a river I know, like the Gorge or the Gull, for comparison. Trouble is, there's no water in either one.
Maybe we could hook up sometime in November, if it rains.
Geoff
Wendy
trim cockpit rim
Post by Wendy »
Al or others who have Taureaus- Do you think it would be safe to trim the side rim any to accomodate larger thighs? Like 1/4 inch?
Al Greve
Post by Al Greve »
I`m not sure what you mean, are you asking about the seam along the side of the boat or the side edge around the cockpit ? I`m thinking you mean the side edge in the cockpit, you could but the further you trim the further you take the sides down which would mean a wetter boat. I guess it would be ok as long as you did`nt trim to much, so I don`t think a 1/4" would be to much.
Al
Wendy
Cockpit trimming
Post by Wendy »
Al, Thanks for the feedback.
