Length: Just about 10' on the nose
Width: 23" or so
Volume: Full cut is 30 gallons or so (same as a my Master Cut Acrobat, which is low cut for 185lbs).
Depth (e.g. height of cockpit rim)-7" (same as the aforementioned Acrobat-you'll notice that the volume was removed not only from the width of the boat, but on either side of the "turret". In this "full cut" version there is still a decent amount of volume in the far bow and stern. Cutting a little out of the hull (which is very easy to do) will enable lower cuts for lighter weight folks...such as myself
I'm 5'9", 160lbs+ right now, 32-33" waist right now, in case anyone is curious. The skirt is a Mountain Surf which also fits my Wheelboy, Cascade, and enlarged Viper cockpit rims. (as well as the Groove
The "other" boat in the images is a Master Cut Acrobat. 10'6" or so, 30 gal. volume (I measured that today as well, as I was curious). Good news for you, eh Mike? The volume distribution is definitely different though
![Image](http://www.cboats.net/images/maven/maven/amaven.jpg)
![Image](http://www.cboats.net/images/maven/maven/bowhulls.jpg)
![Image](http://www.cboats.net/images/maven/maven/bowdecks2.jpg)
![Image](http://www.cboats.net/images/maven/maven/hulls.jpg)
![Image](http://www.cboats.net/images/maven/maven/sides.jpg)
![Image](http://www.cboats.net/images/maven/maven/bowdecks.jpg)
![Image](http://www.cboats.net/images/maven/maven/sterndecks2.jpg)
Outfitting is pretty much done, with the exception of the tweaking I'll no doubt be doing AFTER the pool session (and during
