Hi,
I have broken one side of the thigh brace foam on my CUFly You know the bits that fit either side of the saddle where your knees go.
Does anyone know if the Pyrahna Spanish Fly foam thigh braces fit the CUFly. I live 20minutes from Pyrahna here in the UK, but getting the foam from Robson in Germany may be more of a problem.
Col
CUFly thigh brace foam
C - UNIT..!
- ghetto johnny
jeeez! it broke? wonder why?
Tip #1 Find the search function on this website.
Tip #2 keyword in "outfitting" and "CUFly"
Tip #3 read, read, read, read, read, read, read.... and when your done read it again.
Tip #4 remedy the problem via the advise given.
Tip #5 take your time, fix it once, fix it right, paddle, paddle, paddle.
Craig
You can make SPFly pieces work but watch the width to make sure they are wide enough. You may as well get a pair of knee blocks.
Craig
