CUFly thigh brace foam
Col
Post by Col »
Hi,
I have broken one side of the thigh brace foam on my CUFly :cry: You know the bits that fit either side of the saddle where your knees go.
Does anyone know if the Pyrahna Spanish Fly foam thigh braces fit the CUFly. I live 20minutes from Pyrahna here in the UK, but getting the foam from Robson in Germany may be more of a problem.
Col
C - UNIT..!
ghetto johnny
Post by ghetto johnny »
colin,
first off great last name
what is it about guys named Cartwright that paddles both a CUFLY and a Spanish Fly?
jut kidding
i have switched mine out a couple of times before they were glued in
i was waiting on foam to get in
hope it helps
John Cartwright
Cincy,Ohio
USA
Craig Smerda
L'Edge Designer
Post by Craig Smerda »
jeeez! it broke? wonder why?
Tip #1 Find the search function on this website.
Tip #2 keyword in "outfitting" and "CUFly"
Tip #3 read, read, read, read, read, read, read.... and when your done read it again.
Tip #4 remedy the problem via the advise given.
Tip #5 take your time, fix it once, fix it right, paddle, paddle, paddle.
Craig
You can make SPFly pieces work but watch the width to make sure they are wide enough. You may as well get a pair of knee blocks.
