Questions about minicell.
Today we were making four saddles for our local club, using standard 22 minicell, which was white in color.
The guy who brouoght the foam from Kansas City said that the wholesaler had a "400" minicell. This '400" minicell is essentially twice as dense. We were discussing whether it would be good for saddles. Has anybody used it? If so what are your thoughts.
Regarding the white foam, we got it very cheap but it shows every seam, spilled glue mark etc. has anybody painted or colored foam? If so what worked or did not?
Thanks, Chris Kelly
Thanks, Chris Kelly
I haven't used it, but twice as dense may be a good idea for saddles. They won't compress as quickly. If they're too dense (stiff) to be comfortable, you could always make them 3/4" shorter than you need & glue a piece of 3/4" cushy foam on top. That would also hide the seams. The grey stuff shows seams too. If you spill glue or just want to hide the saw marks, hit it with a random orbital sander. I've found that makes my foam work look much better.
(Now) Sweet Composites sells only 200-series Minicell, although in two grades. See Sweet Minicell Page. I've never seen 400 Minicell, but I'd be afraid of the extra weight.
But I'm lazy.
But I'm lazy.
Yeah, I was also thinking about the weight.
We did consider the concept of a two part saddle but I have always been satisfied with the usual "200" foam.
As to the white color, we will use the sander to clean them up but the white really does show the seams. Chris Kelly
- Jim Michaud
Are you mounting the minicell layers on edge or horizontally? If you build your saddle with the layers laid horizontally you could always use one layer of black 200 minicell as the top layer. I often build my saddles this way using old ethafoam left over from the early eighties.
Another advantage of laying the minicell horizontally is that it's easy to make the bottom layers wider than the top layer. This will prevent the saddle from tipping over, especially if you're building a free floating saddle.
If I not such a computer imbicile,
I could take and post pictures of the saddles.
We use the foam on end as follows:
We were making "Cliff's Fat butt Saddles", so named because of the construction. Using 3 1/2 inch wide foam we cut to form using a wood form. Then glue 2 cut sections and add a wing to each side(hence the "fat butt" name). We then cut, shape and sand.
The result is that the saddle is 7 inches wide at its front end and closer to a foot under your butt. Often we cut a hole right in the front where one may place one's nauglene bottle. Generally we run a thwart over the back of the saddle behind the paddler's back. I have tried 2 different methods of securing the saddles to the thwart. One was to drop a dowell through the thwart and into the saddle. After some time the movement of the saddle snapped off the screw holding the dowell in place. The other method is to place a small block of wood, maybe a 2 incher, on each side of the saddle secured to the bottom of the thwart. This has worked better.
We also usually go over the saddle with a heat gun. This makes the saddle look better and tends to remove or melt or camaflauge small defects in the cutting and shaping.
We are still considering whether or how to paint or color the white saddles. Chris Kelly
Chris Kelly
Chris Kelly
- BlackFly Canoes
This might be a silly question, but does it really matter how it looks? I mean, after all, you are putting your butt on it...
The biggest problem I have with white minicel is people asking me "what kind of foam is that" Seems that most people haven't seen the white stuff...
If it really matters, once you've got things shaped just right, I'd cover the whole works with some thin neoprene.
Jeremy
Jeremy
Oh, the appearance thing is just ego;
wanting one's work to look good. Also, there is the compulsive canoe outfitter in me who wants to know if I can sucessfully paint/stain minicell. CK
Jim, I must admit that I never thought of using the sheets of foam on their sides. You are certainly correct about being able to have a wider base that way.
