info on harmony C-1 skirt?
by mel
can someone tell me if the
harmony C-1 skirt would fit
a dagger atom c-1 ??
mel
Posted on Aug 30, 2002, 12:57 PM
mine fits...
by DaveP DaveP
i have a perception / harmony c-1 sprayskirt, that came with my gyramax. i have jumped in my friend's atom before, and the skirt fits well (the hip grabbers are not a problem), has a tight seal, and does not require a pry bar to put in place. rolled several times to make sure it would not pop unexpectedly. hope this helps.
safe paddlin',
dave
Posted on Aug 30, 2002, 3:46 PM
Hey, Mel...
by Ric Taylor Ric Taylor
If possible, do you know what the measurement on your Atom cockpit(Length and width from outside of the coaming)is? It wasn't on the Dagger site.
Maybe I can get the Harmony skirt to stretch for my Slalom boat.
Ric
Posted on Aug 30, 2002, 8:41 PM
with the rusty tape
by mel
i measured the cockpit to be
21" wide and 26.5" long,
with reverse key-hole size
wider in the front than in the back.
you have a slalom with a cockpit thats
not round?
mel
Posted on Aug 31, 2002, 4:14 AM
Thanks, and not quite....
It's 20 X 24 so sort of oval, I guess. I'm starting to feel like Goldilocks; everything is too big, too small, too tight, too loose; I want one that's JUST RIGHT!
Thanks for measuring,
RT
Posted on Sep 1, 2002, 5:22
atom review
by mel
At 9'8" in length, the Atom is a sleeker, shorter boat than Dagger's
C-1 Cascade: It is 16 inches shorter, four pounds lighter. Built from
EXL polyethylene, the Atom is 26" wide, weighs 43 lbs., with a
volume of 66-gallons. The cockpit is 24" long by 19" wide. The
recommended paddler weight range is 115-215 lbs.
-this was from the release dated april 18,1997
i know measure twice cut once
sorry about that
mel
Posted on Sep 3, 2002, 2:49 AM
