What's the best position to attach the lapbelt to? I put hip grabbers on , and have re-attached the lapbelt to the furthest back bolt on the hip grabber. When I crank it down its almost horizontal across the boat. When I lean forward I don't lift off the seat, but my butt aint pressed against the backrest as much... does this matter?
Do folks have their lap belts attached a little further back, IE where the back rest is? or does it really matter all that much?
I haven't tried it on water yet, thought I'd ask first.
Mike.
________
Sauteing food
lap belt placement.
lap belt placement.
I have the lapbelts in the front holes where the yak seat used to be on both of my conversions. They are both Wavesports, a Big EZ & a Forplay.
Is it horizontal when you're in it? My seats are 8" high, so the tops of my things are above the rim & the belts do a good job of holding me down. Then again, I am a larger gentleman
Here are photos of the Forplay:
http://pg.photos.yahoo.com/ph/wh20crazy ... /my_photos
I attach mine about even with my back-rest so that the belt extends forward before crossing my lap. I stay locked in the seat prettty good.
I use an airplane seatbelt. I drill two holes in the release gate and attach a practice golf ball (a mini wiffle ball) to allow me to find the release the buckle easily with either hand.
To attach the seatbelt, I use 2 pieces of aluminum mounted with one on the inside and one on the outside of the boat with 2 bolts to distribute the pressure on the hull. I learned this the hard way by pulling a bolt through the boat.
