Help end my floatation nightmare!
boatbuster
Post by boatbuster »
Air bags are the worst thing about open boating. I have had nothing but trouble with the ones I have bought, especially the ones made by a company called Headwaters. The seems bust or they spring leaks and they are cheap and worthless, but cost an arm and a leg. Any good sources for open canoe air bags that last?
msims
Post by msims »
The voyageur (er?) bags are pretty good, IMO - you can sometimes get them online at www.sierratradingpost.com - I got kayak float bags (AHEM! for my C1) at 15 buck a pair...
I'd say they're the best on the market - and reasonably light...
ChrisKelly
I am surprised b/c I use Headwaters bags all the time and
Post by ChrisKelly »
have great luck. I like the nylon ones because they are lighter and more flexible. I am hard on gear. I almost always take the bags out for long drives but often go 100 miles with them in. I attach them with a fastex buckle in the bow and stern, with three ties down points, with a strap and your usual string cage.
Things that have caused problems for me are having the end of a bolt abrade the bag, driving with the bags empty (the flapping can tear them up), and abrasion from the string.
Although I have sucessfully repaired bags that have pulled away from the valves, usually a hole near the gasket is fatal. For holes in other places I have decided that duct tape is as good as anything. It is quick and lasts literally years.
Oh yes, I am subject to attacks of airbag anxiety, esp when driving over the Divide or on the Cherolloah. I am compelled to stop and check a lot which drives my wife crazy.
Jim Michaud
Post by Jim Michaud »
Try Aquaseal for repairing air bags. It works great. I always thin out the Aquaseal with toluene first.
Jim
ChrisKelly
I am wrong. My bags a Voyeuger. The Nylon kind.
n/t
Louie
I was goin to say Judge
Post by Louie »
I worked for the company that was the parent company of those bag and Headwaters didn't hold up for me. But once I put a set in a boat then don't come out till some scaq on an old pine hooks um and pulls them out.
I've had Perception/Harmony bags in my open boats since I bought my first in '91 - come to think of it, I think that is the only kind I have ever had. I've had really good luck with those, a couple of my original bags (second hand even then) are still serviceable. I've gotten some new ones in the last couple of years from SierraTradingPost.com.
I try not to travel far or fast with them in the boats. In one Mohawk I had the factory set up with the strap and buckles - I would deflate the bags and compress them into the ends. That saved the fabric from the wear and tear from flapping. I also make sure the inflation tubes are secured so they don't flap.
boatbuster
Thanks guys...Can't wait to meet you at Single Sticker Fest
Now another question. What is the best source for Voyageur or Harmony air bags? I have a pair of Harmonys in my Superfly and they have held up OK except for some leakage around the hoses. I would be willing to spend a little more for some Voyageur nylon bags if they would last and since their stuff is gauranteed. The NRS bags seem good too. I wouldn't mind them for my C-1, but I can't go for that ugly gray color in an open boat.
The seams on the Headwaters bags are crappy. If that company was still around I would try to send them back.[/i]
RodS
Post by RodS »
I had good luck ordering from here:
http://www.riversports.com/index.php
Tiggy
Post by Tiggy »
Got some 60" from NOC, so far so good.
"Don't Panic"
<a><img></a>
