Well I made a new patch and have no idea
ChrisKelly
Post by ChrisKelly »
if it is going to work.
My old rolalex Rival has had many repairs, including new gunnels (oak), a large kevlar patch under and in front of the saddle including kevlar strap tiedown points and a big kevlar patch on the outside stern. (which is also in need of new resin).
There is (was I hope) an 8 inch split in the inside stern goin deep into the foam.
I cut away some of the foam, lifted the lining and forced a new glue I am trying up under the foam and floor. I also filled the hole with this glue. The glue is called "Anchor-tite. It is a waterproof marine 2 part epoxy by Dvcon. They say that it is vibration and shock resistant and is supposed have 30% flexibility (whatever that means). You can apply it underwater.
Like I said, I have no idea if it will work, or more exactly, for how long it will work. I am sure it will keep water out until it cracks. How long that will be or how hard a wack it will take is a complete mystery.
I'll try to let you know when and under what circumstances the patch goes south. Chris Kelly
Post by Paddle Power »
Interesting, do keep us informed of how it worked out. I should address some of my repair jobs...
