Play Full C1 Conversions?
I have only paddled an Atom and Cascade but tried out a Mr. Clean conversion at the pool this week. It was a very play full boat, easy to start bow stalls and with practice I thought I could get it to do bow stalls and even cartwheels. So I am now seeking advice on kayaks to convert that are more play full. I weight about 200 lbs, 6’ and have big legs. Hoping there are some recommended older designs like a Medieval, Big EZ, Super EZ Or Honcho so I can pick one up at an attractive price.
summer
Hmm
More knowledgable folks than I will hopefully chime in on conversions, but you may want to check out the following:
-Score
-Big EZ and Super EZ, as you mentioned
-ForPlay (if you're up for a "lower volume" boat for your weight).
Searching on any of those boats should turn up a lot of info and opinions on them.
-Score
For conversion... Large Fluid Flirt. http://fluidkayaks.co.za/Whitewater_L_Flirt.htm
These days I'm ~195 & counting Wavesport uses big cockpit opennings which are great for getting out of the boat. The Super EZ has a huge opening. I've got both a Big EZ & a Forplay.
I love my Big EZ for play. It's great on a steep wave. This boat loves to carve. It has enough bow rocker to keep it from pearling on those steep waves too. Stern squirts are effortless. A couple of quick forward strokes & a weight throw will stand it up on the bow in flatwater. The drawback is that it's slow. At my skill level I wouldn't paddle it on anything harder than the Ocoee.
I've got some photos here:
http://new.photos.yahoo.com/wh20crazy/a ... 2349974946
I've changed the outfitting since the photos were taken. It now reflects my Forplay outfitting:
http://new.photos.yahoo.com/wh20crazy/a ... 2349975259
Lame video here:
http://www.americanwhitewater.org/photo ... /14023.mov
The Forplay will surf waves that are not steep enough to hold the Big EZ. I'm guessing this is due to the ~foot of extra length & not having as much rocker. It does not carve as well as the Big EZ, but it spins better. It's the best back-surfing boat I've tried. You have to keep it moving on a steep wave so that it won't pearl out. If it does pearl out, go with it. It shoots WAY up in the air & I can usually spin it around & land vertically on the stern The ends are slicey but not wingy. You can squirt it but it's kind of forced, not finessed. I have to be careful of my tilt on ferries since the bow kind of wants to dive.
Of the two, I'd recomend the Big EZ.
Lame video here:
The Score is the bigger version of the Foreplay - faster, more buoyant, but still quite squirtable with your weight and height. Search on that in this forum for more lengthy commentary. I love mine, it's as short a boat as I want.
good suggestions,
Big EZ, Super EZ, and Large Fluid Flirt.
i'm not a fan of the ForPlay or Score.
Session+
After reading the replies I was focusing on a Big or Super EZ but I have found a Session+ for a good price. My concern is the 24.4" width over the 26" to 27" width of the EZs. At 200 lbs will the Session+ be a lot more unstable than the EZs?
summer
I've tried a Session, but not the +. I found it a little tippier than the Big EZ. The bow looks weird when you're surfing. Don't open your mouth when surfing. If it pearls, the water hits the knee area & shoots straight up into your mouth. It surfs real nicely & despite the shorter length, it's no slower than the Big EZ.
