Zephyr or Paradigm
Zephyr or Paradigm
I just put a deposit on a Zephyr and need some advice. I've paddled one once and loved it. I've also paddled an Ocoee several times and loved that boat as well. Should I consider trying a Paradigm prior to making this purchase?
I'm 5'9 185lbs
Thanks!
-phil
I'm 5'9 185lbs
Thanks!
-phil
How solid is your roll?
What do you want to do with the boat?
I have a Zephyr and have had the pleasure of paddling it 5-6 times before the D-rings blew out (the old glue, haven't built a bulkhead yet) and love it. To me it is not the most aggressive boat around, but forgiving - I feel comfortable trying harder moves in it. I've paddled a number of the rivers you mentioned (in a Mohawk Viper) - I would feel very comfortable running them in this boat. [If I can ever get away, I will run them...] Despite my D-ring failure (the new glue corrects that I hear), I am sold on the material - light and strong.
I have no experience with the Paradigm nor any particular opinion on its design.
sbroam wrote: To me it is not the most aggressive boat around, but forgiving - I feel comfortable trying harder moves in it. .
Do you think that an Ocoee or a Solito is a more aggressive boat?
I paddled a Zephyr about 3 miles of class II plus and surfed it quite a bit Wednesday, and really liked it. It's been so long since I paddled an Ocoee I can't remember how it would compare.
Parrot Head Paddler
Big paddler in Zephyr
I am 250lbs+- per season. Anyone near my girth paddled this boat? How does it react to the weight?
Randy -
Can't compare to a Solito as I never paddled one and it's been a long time since I hopped in an Ocoee. But, I'd say it is comparable to the Ocoee, but not as edgy. Very similar feel to the Viper 12 (but shorter), similar edge (less? maybe not). [I remember folks saying the Viper 11 was a bit different than the 12, never tried the 11]
Swimmer -
As for weight, I'm about 220# and it handles me fine. Hard to say how much reserve it has - you'd be welcome to try mine if our paths cross. I'm in SC and hope to make the canoe shindig in TN.
Swimmer -
Swimmer,
I paddled the nitro at 240#s and because of the double chines, the hull is quite narrow, it sinks quite a bit... you might want something with a softer chine, zypher would be a good candidate...IMHO - I havent paddled one yet but hopefully this spring summer...
As your weight goes up you sink, making your a lot more vulnerable to side currents if you're not on with your edging - if 6" of your boat is upstream on current and the chine is hard you'll windowshade pretty quick. If you have a softer chine, maybe not as quick.. and might be able to counter a little more..
-- Cya
I decided to just go ahead and buy the Zephyr. I did get to see a Paradigm at NOC on saturday. It looks exactly like a cross between an Ovation & Phantom, neither of which I care for. I'm sure that it may have some differences. The green color is a lot better in person. I actually think its a cool color.
Either way I'm glad to be the proud new owner of a Zephyr!
-phil
-phil
Zephyr or Paradigm
And immediately change straps to bulkhead
Paradigm
Check out Bob`s comments on boats and the industry in general:
http://www.bobfoote.com/bob/bobesquifrealationship.htm
