Look for other places to search for used OC1s
Hi, beside this board, can anyone recommend some good places to look for used OC1s? Are there some other boards/lists that are often used? I'm located in Lethbridge, Alberta, Canada and willing to drive a few hours into Montana or BC to get a boat. Thanks
For local stuff try posting on calpaddle, its mainly kayakers but they may know of open boats:
http://www.calpaddle.com/calpaddle/category-view.asp
Aquabatics in calgary are also hosting a gearswap end of april, you might have some luck there.
http://www.aquabatics.com/default.asp?V ... DOC_ID=776
You could also try posting on the forums on the kayakwest site, again mainly kayakers, but worth trying.
http://kayakwest.com/joomla/
For local stuff thats all I can really think of, I'm sure someone else has more info. For US, no idea, you could post/search on boatertalk gearswap page for ads in montana, but again, mostly kayaks.
Brad
Brad
You should take a look at the Mountain Equipment CO-OP site
www.mec.ca
Go to the "Connect" tab and then use the "Online Gear Swap" link on that page. Once you get to the Watersports section you can narrow the search to Canoes. You'll see a lot of tripping boats but there are usually a few WW boats too.
Another option is to use Google to search the Craigs List site. You can limit the Google search to that website by adding "site:craigslist.org" to the search criteria.
A third options is the classified ads at www.paddling.net
Again, lots of tripping boats with the occasional WW thrown in.
Hope this helps.
Dave
www.mec.ca
Hope this helps.
Dave
In addition to MEC, I'd check on myccr.com (Canadian Canoe Routes), not just searching the classifieds, but a post as you've done here.
And get in touch with local whitewater clubs, I'm pretty sure there's a kayaking club in Lethbridge that would probably know of any open boaters.
And KanFest is coming up near Canmore, so whoever organizes that might have an active forum of somekind.
Good luck, PY.
Good luck, PY.
