help my roll keeps failing!
hi,
i paddle a spanish fly, unfortunately my roll keeps failing. i know the theory of the roll, i think that my head keeps coming up early but can't seem to stop it! does anyone have any tips or ideas to help me get my technique right.
brockers
brockers
Try keeping your head touching your paddle until you are completely up, then even hold it there for a second or two to try and over exaggerate the feeling. This worked for me when I had a few probs with mine.
i r a p|r@t3
yeaaaaaaaarrrrggg
yeaaaaaaaarrrrggg
as you initiate the opposite side knee, to push down on the boat and pull it back up underneath you and you feel your back start rising out of the water, push/drive down on your paddle. it'll give you a little more momentum to pull the boat back underneath your torso. let your head "drag" back into the hull, as looking or lifting up too soon may cause you to become unstable and lose your roll.
try to get fully extended on your set up. think perpendicular.
my .02
my .02
Re: help my roll keeps failing!
I had this issue for a long time in my Skeeter and didn't know it. The little trick that works for me is after initiating the roll, to watch the oposite gunwhale underwater and try to pull it towards my face. Everybody's different, though.brockers wrote:hi,
ii think that my head keeps coming up early but can't seem to stop it!
Pretend your head is superglued to the back of your shaft
hand until the boat is completely righted.
here's my tip, this is for a c1 but im guessing same applies in your boat. This helped me much recently.
Two phases to the roll, it's important to keep these motions separate: hip-snap/initiation, then followthrough.
Of course i'm over simplifying, but this worked well for me - you snap first, get your boat up on edge, then follow through. (keep your head low like they said.)...
Mike.
Mike.
-- Cya
PS....
Make sure you are connected to the boat well. I can roll mine easily without straps in still water, however in bouncy water you really need a good firm connection to the boat to ensure you transmit all the motion correctly.
Without seeing I can not say whats wrong, but try working on your low brace...Use the correct techbnique !. Get it lower & lower & lower, getting the boat further over every time. Get comfortable with doing this.
The recovery from a low brace is exactly how your roll should be finishing.
Being familiar with the finish position should help you get there!
Good luck..
Good luck..
Rolling
well you need two paddles sir. Duct tape the shaft of one around your helmet . be sure to get the blade pitch right . the other blade is one you paddle rivers with. when you flip simple let go of the paddlein blade and reach for the taped one. ( it will already be in the proper position. then simply hipsnap up. it worked for me. JIM syotr
open boat rolling
I paddle a Spanish Fly as well. As everyone else said, look for the logo on the side of your boat; i.e. keep your head down. The other part of the roll is legs, legs, legs.
One problem with the Fly is the height and shape of the boat. My elbow kept hitting the bag cage. The solution is to sweep the paddle slightly forward in the last stage of recovery. This helps get your elbow over and around the cowling.
My roll's now pretty much bomb-proof, unless I get knocked out, last last week on the Gull.
Geoff
Geoff
Let me repost this
I have a bad habit from Boatertalk of starting a topic in the subject line and continuing it in the message body, so it appeared incomplete. Let me say this again, this time all in the same place:
Pretend your helmet is superglued to the back of your shaft hand on the paddle until the boat is completely upright. Then and only then does the glue release and your head come up. But instead of pulling your head straight up, keep it low in the boat as you swing it across toward the opposite gunnel. Hope this helps
