Messin' with thwarts
Willard
Post by Willard »
I have an old ('89) Bluehole Sunburst OC-1. I don't like the beaminess and thought I might experiment. Has anyone ever adjusted the beam (the plan is to remove the aluminum thwarts and hack off about an inch) on an OC-1? I wonder what it might do to secondary stability, etc.. However, for the sake of the c-boat community, I just might go ahead if it turns out that this has not been attempted. Please let me know if you have experience in this realm.
In the saving of places of natural beauty and wildness we are waging a battle for man's spirit.
Sigurd Olson
cheajack
Post by cheajack »
Heck, my Ocoee is pulled two inches. Why don't you make some wodden thwarts and cut 'em two or 2 1/2" and if you don't like the result you can always spread it and put your old aluminum ones back in?
Mike W.
Post by Mike W. »
I second cheajack's idea.
Generally you'll lose a little rocker & some primary stability by pulling it in. You'll gain some speed too :D
rnbeals
Post by rnbeals »
My 16 foot Dimension is far from an OC-1, but I tinkered with the thwarts because I bought it without thwarts, decks or seats.
My experience is that the biggest effect of pulling in the thwarts is loss of rocker, making the boat longer and faster. The gunwales are tighter but the waterline hull cross section was not affected much.
I finally got measurements off another Dimension and returned it to its original shape - I think the original design worked best (for this boat).
Rich
Carpe Canoe
I tinkered with my ME and took some measurements a while back - results here :
http://cboats.net/cforum/viewtopic.php?p=9766#9766
I'm thinking of tucking it in some more...
ezwater
Post by ezwater »
:wink: Y'all pull in your gut and leave your boat alone !
pblanc
Impulse
Post by pblanc »
I have a Dagger Impulse that I have set up primarily as a whitewater tripping canoe pulled in about 1 3/4 inches. It did make cross strokes easier and seemed to improve speed and tracking a bit I presume by decreasing rocker and increasing waterline length.
Willard
Post by Willard »
I like the feedback! :lol: I will try the oak thwarts and save the old aluminum ones for a refit if things don't go well. As it turns out, we had some big limbs cut down from a nice red oak in our yard, so I'll hack two thwarts out of that and screw 'em in. Now all we need is water up here! :( Thanks again for the ideas!
Sigurd Olson
philcanoe
Post by philcanoe »
have experimented using c-clamps and longer wood, on flat - but moving water...simply placed across gunwhales and clamped....made it real easy to dial in desired width... go too wide, go not wide enough....also can lay boat on flat and measure rocker change... learned a lot about the boat, different hull materials, and how it affects performance for THAT hull
