the martikan and Hochschorner paddles are impregnated with color in the micro-balloons... so the color is in the epoxy. Dave Florence also uses that same paddle, just clear carbon.
But I learned from Trevor Soileau that the Appliance paint works great for painting paddles, it abraids very well, and doesn't chip, but I did like 4 coats. I then went on to paint it blue with a general spray i think. and that held up until I snapped the blade off the shaft... the tiedye would be best i think if you were able to get it and then clear coat the crap out of it...
cheers
-isaac
Slalom video from Slovakia and Europeans...
mike, just wet sand it downand then do multiple coats, and use an acrylic, it seems to stay better. you also have to do like 5 coats if you spray, and a clear coat a few times. It works, it's just way more time consuming than you think it will be.
and interesting about the red dot... Nic Borst has a red paddle...
Cheers
I get cut in t-minus 3 hours...
-isaac
Cheers
-isaac
