Paddling on your weak side
Do you feel comfortable paddling on your weak side. (in turbulant water)
Poll ended at Sun Jul 06, 2008 2:30 pm
yes
12
43%
no
16
57%
Total votes: 28
cbcboat
Post by cbcboat »
Just curious how people feel about paddling on their weak side ie, I padlle on my right so paddling on my left would be my weak side.
I usually, when actually paddling through rapids always paddle on my strong, then in the flat paddle on weak side a bit. I know I should try to do more with my weak side. Just wondering how many of us feel comfortable on both sides
the great gonzo
Post by the great gonzo »
I tried to develop my weak side for a while, and found it not to be worth the effort. I'd rather have one really good side than two so-so ones. If paddling strokes on my left is required, I just use offside (crossbow) strokes, I feel way more comfortable doing so than paddling on my left.
In flat water it's a different story, when trippinng I do switch sides if one is tired, but in WW, no way. I can paddle lefty in a tandem, but I do kinda suck at it.
Last edited by the great gonzo on Thu Jun 26, 2008 4:18 pm, edited 1 time in total.
oopsiflipped
Post by oopsiflipped »
Either Martin or I misunderstand this one (or I just misunderstood Martin...)
Are you talking crosside or switching from righty to lefty B? I though you were talking cross side.
the great gonzo
Yes, my post was confusing. What I meant to say is that I'd rather go to my offide on a crossbow stroke than switch sides entirely.
yarnellboat
Post by yarnellboat »
Coming from a tripping background, I'm OK on either side. Left is my strong side for ww, but I don't mind running some stuff on my right.
If I get C-1ing more, my right will improve, because I can only roll on my right, so I stick to my bad side when paddling C-1, which is Ok, because for now I'm limited to farting around on really easy water.
PY.
KNeal
Post by KNeal »
Aw, Martin. Your post was not confusing. People just have to read it like they are a multi-international Canadian! :lol: I agree about maintaining a dominant grip through whitewater and making good, strong cross-strokes. Otherwise, you're stuck paddling on one side and spending time bracing defensively instead of paddling offensively. I learned that point early on when I took on the Upper Yough. Defensive bracing made it a lot tougher navigating through the rapids. When I learned to trust my off-side strokes, going through the rapids got easier, though my comfort level on the Upper Yough never got much better.
You're a much better cboater when you develop good off-side techniques (right, Bill Hay, Alden, Joel?). I do recall hearing/reading about Jon Lugbill and Davey Hearn saying that offside paddling was not necessary in a cboat, that you could race onside and do just as well. Fact or fiction?
KNeal
oopsiflipped
I thought CBC was asking about cross strokes. I can't paddle lefty in an eddy, much less in whitewater. Don't think I can change my vote though.
KNeal
Post by KNeal »
FWIF-paddling on my offside means taking cross-strokes and not switching hands.
KNeal
cbcboat
Post by cbcboat »
I was meaning NOT cross strokes, actually switching hands and paddling on the other side.
B
craig
Weak Side?
Post by craig »
Ditto to Martins post. I can only paddle on my weak side decently when I'm tandem, then it's only marginally acceptable. Sorta like switching hands for handwriting or eating with a fork and knife; its messy.
Post by Bob P »
I don't have a weak side.
On the other hand, I don't have a strong side either. :roll:
jscottl67
Post by jscottl67 »
Bob P wrote:I don't have a weak side.
Are you amphibious? :P :wink:
John Coraor
Post by John Coraor »
As a result of starting out tripping in open canoes I am still comfortable switching sides in open canoe - certainly in up to Class II, possibly III. In decked canoes, my tolerance for switching sides is much more limited. I have always paddled left in decked canoes and don't feel comfortable on the right, primarily because I just don't have any where near the same degree of edge control and I find that it is much more critical in decked canoe.
Aric
Post by Aric »
in an open boat I can paddle up to class II on my left side, in decked boats I stay with my strong side all the time. I think you are right John, its the edges
Aric
bigspencer07
offside stroke(OC-1 crossover) stonger when on "other&a
Post by bigspencer07 »
I'm a righty by nature...however thru past-history(as others) on flatwater...enhancing my/our offside stroke (ie going Lefty via switching hands with paddle)...my OC-1 crossover/offside stroke(as a Lefty) is clearly more powerful. True...I am taking it easy..as I'm still rehabbing my right wrist from sitting on it 2 winters ago...(Don't have a thick, muscular wrist...so it's taking time.. :x ..strength is coming along good, but way too slow for the brain!!..ARGGGHH).
