Ok, first off, glad to hear you hope to make it NZMatt, Kalin!, and Kelly-Rand! it will be good to boat with all of your (and J and Tess) again!
The Hudson is most likely different than most rivers many of you have run in several respects-
1) It's a long wilderness trip
2) The rapids (at "normal" fall levels-3-5') are technical, not big
3) The river, though not as wide as the Ottawa in all spots, is fairly wide-there is more than just 1 line down the river, and with only a few exceptions (namely the class IV rapids) you can pretty much boat where you'd like (although some lines are easier than others)
So, here we go-THE HUDSON:
The first 3 miles are actually on the Indian River as NZMatt stated-3 miles of class III, with one great spot to regroup, and several smaller ones. The first rapid is Indian Head, followed by the FInch Pruyn Islands (regrouping spot, not really a rapid), and Gooley Steps. Also, as NZ Matt stated this is fairly continuous class III stuff-if you are comfortable paddling in moving water (read waves and small holes) you'll be fine. Also, at normal fall levels the Indian, though only class III, will be the toughest part of the day (due to it's continuous nature).
Then the Confluence with the Hudson. This is the last point you can take out for many miles (and even here requires a bit of a walk, but there is a road at least, though it is private)
The first rapid on the Hudson is Cedar Ledges. Class IIish at normal fall levels, IIIish if higher, but really a float and chat for most folks.
We can stop off at Virgin Falls (nice little water fall on the side of the river where a stream enters into the Hudson) and stretch our legs a bit
Next is Blue Ledge-at 5' or so I think it is defined as Class V in an old guide book-I seriously DO NOT SEE IT. Class III, yes, and V when there is A LOT of water, but seriously, it's no more difficult than the Indian. This is the half-way point by mileage, but not time.
Just below this is a GREAT surf wave river right (and a great squirt line above it in Blue Ledge Pool, also river right). There is a public trail into the river at this point (3 miles round trip, I think), and it's a good lunch spot.
The surf wave is the very top of the Narrows, the bottom of which is the first class IV of the day. It is portageable. It features BIG waves (not ottawa-sized, though), and one hold to avoid (very easy to avoid it, again, if your comfortable paddling in moving water).
Below the Narrows is Osprey Nest, a fun little bouncy class III, and a HUGE pool (square eddy) to regroup in).
After Square Eddy is Carters, or Split Rock. There is a hole river center (the appropriately named "Big Nasty" (hear that KNeal? BIG NASTY
) to avoid, but it's super easy if you know it's there. Carters is long, but there are eddys to catch, and it's class IIIish. You do need to watch out for "Little Nasty"(another souse hole) near the end, but at lower levels (3') the rock that causes it is out of the water.
After Carters is OK Slip, which is short with some pools,
This leads into Giveny's Rift, the second class IV of the day, and the most serious water on this section of the river. Again, it is portageable. J. will no doubt have fun playing in it, but the rest of us will most likely just run it straight. It's short, and there is a bit pool at the bottom, but there are a lot of rocks, and the currents are strong. For those that have paddled the North Branch, think of a bigger, longer, steeper Robins Nest. Multiple small drops to paddle through (no really trashy holes at this level, though).
After that is Gunsight In and Out (fun little class IIIs agian), and Harris (aka Mile Long). Fairly continuous class II/III, with a few holes right off river-right on shore to avoid.
Next is Greyhound Bus Stop, and almost river-wide play feature (hole in this case). A great way to end the day is to use what energy remains here
Nice eddy, and very deep after the ledge itself (remember to tuck on those windowshades...). There is also a nice surf wave just above it.
The last few miles are float or paddle, depending on how tired everyone is. If the rive is up (closer to 5') it's a quick float. Closer to 3' and it's a long float unless you paddle (I think it's 2 Miles or so, though it may be 3).
More Information:
To check out the river level
-http://waterdata.usgs.gov/ny/nwis/uv?01315500 (this also shows CFS as well as feet) and more information about the Hudson-
http://www.americanwhitewater.org/rivers/id/1321/.
A consistent role and comfort in moving water is required, as this is a long trip, and it will be fall paddling in New England (as previously mentioned, most folks from south of NYS will most likely be most comfortable in a drytop.) The scenery is unbelievably gorgous (no pun intended
), especially during this time of year (fall foliage).
Anyone else that would like to add there thought on the Hudson, please do so-I've been guiding the gorge for the past 10 years, and it's familiar territory to me-fresh perspectives like NZMatts and others are very welcome.
In case you wonder what sorts of boats travel this regularly, XXX, Z's, Forplays and Scores are not uncommon. The river manager for one rafting company "safety boats" in an S6. I makes for a loooong day, but he has fun.
