Creek boat re-inforcement
philcanoe wrote:
sbroam wrote:... And if not glued in, the abrasion due to sand would certainly be less significant as well...
actually thinking that without glue sand can/will get under or inbtween... while if structure is adhered, then sand cannot get there
D'oh! That was a typo - I meant glued. I need to look at my PE boats that are outfitted that way, maybe clean them out and lay down a bead of caulk if not insert a layer of foam.
