Royalex canoe repair
Plascual
Post by Plascual »
Hi!
I own an old Dagger Legend, made of Royalex, that has seen a lot of rivers and rocks... so I decided to repair it, and give it a second life.
After reading about the ABS/MEK receipe, I initiated the repairs. It's going very well, and the ABS layer is almost done.
The problem is, that when I tried to create a paste with vinyl, it simply doesn't work. It begins to flake and plastic pieces just weak, but it doesn't create a mastic, like with ABS pipes.
I wanted to spray a vinyl plastic layer over the repairs, and even on all the boat, but can't seem to find anything that could do the trick... until yesterday:
Yes, I found something that may interest some of you. It is liquid vinyl plastic paint that can even be thinned with acetone. That's what I would like to use to recreate the outer vinyl layer. I would buy a white gallon this paint, and use plastic pigments to match vinyl color.
Here is a link to get paint's description :
http://store.vernondeon.com/index.php?o ... 2&PID=7286
I would like to have your feedbacks on this idea!
milkman
Post by milkman »
Sounds like a bad idea to me because of this sentence:
Please ensure that you are applying this coating on only new unpainted PVC buoys.
You're going to be applying it to ABS. There might be a problem.
I would suggest using Krylon Fusion spray paint. There's been lots written about it at this site.
Plascual
Post by Plascual »
I will try to get more info as if it does work also on ABS, like you said, it could be a problem.
I think what they mean is to use this liquid vinyl only on pcv-like material, with no paint. As the outer layer of Royalex canoes is vinyl and not paint, I think it could be a great alternative since acetone will recreate chemical links between the original vinyl layer and the new sprayed one.
I think this paint is a different blend of MEK, Acetone, and another composite. That's why it couldn't be dissolved with only MEK.
I'll give more feedback on my researches.
That could be interesting. Note :
* I have been using Acetone + ABS to make the paste, not MEK (at least not any more). Both work fine, but MEK seems to be the nastier chemical of the two.
* Krylon Fusion (and the comparable Rustoleum product) do protect the ABS from the sun, but, the add no abrasion resistance - they both readily leave their mark on rocks...
ChrisKelly
I used MEK + ABS and it worked fine.
Post by ChrisKelly »
Course, it is all busted up again but that is after a GC run, some Numbers, a dozen Fractions, some Daddy's and whatever else.
I wuz happy with the repair.
Plascual
Post by Plascual »
Hi all!
I just wanted to keep you informed about my project.
I ordered the flexabar vinyl plastic paint, and I finally got it this morning. I've done two tests so far, on ABS and on PVC, and it is working very well. I dries to the touch under 30 minutes, and cures overnight.
I'm not surprised that it works also on ABS... on the manufacturer's website, I was written that it works with PVC, EVA, Polyurethane, Polyethylene and Styrofoam. While Styrofoam is only a trademark, it is made of polystyrene, just like ABS is. I don't think I'll be getting any problems.
I'll keep you in touch with it.
jnorto01
Post by jnorto01 »
Looks very interesting. Please keep us all informed on how your product test works out. Looking at the picture of the can, I see this paint is either made in or distributed from a company in New Jersey.
Seems like that is were all the good chemicals come from. There should be a US source for this stuff. I'll have to do a search. Thanks for posting this up and please give an update soon. Jim
jroneil
Post by jroneil »
Here is a place in New England probably get it at any coastal area
http://www.newenglandmarine.com/Lobster ... 0paint.htm
Plascual
Post by Plascual »
Some news...
okay, I tried to pigment the white Flexabar paint to dark green without success. I didn't thought that it would be so hard to get the color from white. So next time, I will order directly from Flexabar, and will ask for the good color. I just dont know how to define the color I want ? Maybe using the pantone color matching system ?
jnorto01
Post by jnorto01 »
When I looked on the site it seems the paint comes in a good but basic color selection. If you need a dark green, buy the big can of green and a smaller can of black and custom mix it. Typically most colors can be darked a shade by adding black to them. Go very conservative when adding the black. You could try a small batch and do the addition by weight if you have access to a good scale. Document your mix ratio so you can duplicate it if needed in the future. Good luck and keep us posted. Jim
Plascual
Post by Plascual »
Thanks Jim, I bought the paint as fast I could, and didn't realize that I could simply mix different can... well, anyway it is done. Maybe next time. :-)
I've done a little trip last week with my Legend and I think the repairs are great and there are no scratches on the paint... so I think Flexabar paint is great to replace the outer vinyl layer.
I hope this will help many people keeping their boat a lot longer.
Fine! :) Now, let get dangerous!
Plascual
Plascual
Post by Plascual »
I forgot to tell that I applied the paint with a air spray gun. I thinned the paint a bit with acetone.
Tiggy
Post by Tiggy »
could always do a second coat :) W/color
"Don't Panic"
<a><img></a>
