mini cell removal
Ulysses
mini cell removal
Post by Ulysses »
Recently bought a royalite boat with minicell kneepads in the wrong location.
What is the best way to remove them with minimum damage to the hull?
Thanks ahead of time.
Mike W.
Post by Mike W. »
1st try just pealing them up. If that doesn't work try a piece of cross-connect wire (24 gauge, get a few feet from a phone company guy). I wrap the ends around tent stakes & use it like a saw. The wire doesn't work well in curved areas, so light use of a random orbital sander will finish the job.
ncdavid
Post by ncdavid »
I bio-engineered some bacteria that eat minicell and excrete vinyl. I can send you a vial for a small donation....
Jim P
well
Post by Jim P »
if none of the above work
just convince those knee pads that they are my hair and they will fall right out :o
Ulysses
Magic powder
Post by Ulysses »
Perhaps a touch of the bioengineered powder will restore your hair. Do you like red or green? :D
c1swim
Post by c1swim »
Seriously, If they won't peel up by brute hand strength, take a hacksaw blade (just the blade) and slip it under the pad and saw as close to the boat as possible.
Now, you should be left with some mini-cell and glue residue on the boat.
Goof-Off, allowed to soak for a minute, and a plastic scraper or scuff-pad will remove the rest.
Hope this helps.
dance for rain
Ulysses
Goof off
Post by Ulysses »
Goof off. Good idea. I was going to try Nair.
Thanks.
dafriend
GMV
Post by dafriend »
ncdavid wrote:I bio-engineered some bacteria that eat minicell and excrete vinyl.
However, the dangers of releasing a Genetically Modified Vinyl (GMV) into the environment are completely unknown. Suppose this vinyl should mutate once in the wild?!? Who knows what might happen. Paddles could become horrible deformed as they grow an extra blade. What happens if your pedestal becomes infected? Might it dissolve into a puddle of vinyl forcing you to sit on the bottom of your boat using this mutant paddle? :o
The horror... the horror....
Dave
Just leave the minicell where it is and call it extra flotation.
