I removed the float bags from my PERCEPTION Gyra Max C-1
to repair a hole (stupid mouse ) now I am wondering
how to reinstall them. I tied a nut on a string and tried to
get it to pass around the pillar but no go. Next I tied a short
length of small chain on the string but that couldn't find
the hole/gap at the end of the pillar either
I got them out because the cord passed up and under the
pillar do I work it back down that way with a stick?
Installing bags in a C-1?
HarryA \../
There is no nobler use for
money then to buy a canoe.
It is is a gyrodog it don't have a drain plug. If you put one in you could feed the string through the hole tie it on the bad and pull the bag in. You can bo both end and be twice as cool as the butt boater who only have one. If you do put in drain plugs please don't use them however it really slow down the whole trip.
