Instalation of Hip Hugger in C1
Dale
Post by Dale »
:roll: Could someone give me some advice on how to install the Dagger Hip Hugger/grapper into a Cascade so it is flush around the cockpit. Is there some trick to it?
thanks in advance.
Hmmm
Post by Sir Adam »
If I recall correctly from installing one in my cascade, it doesn't quite sit flush. The cockpits are a little bit different. What I did was remove a bit of the rear foam pillar (so the "tab" would fit in there) as well as a piece of the seat. Once that was bolted in (not easy, due to the foam pillar) I used clamps to spread the hipgrabber out a bit (so it was tight to the rim) and drilled and bolted it. I had images around somewhere, but I don't have access to them right now.
Good luck!
PAC
materials
Post by PAC »
Other questions on hip grabbers?
For those with Vipers did you install them on your boats and if so how? :o
What materials where used in general building huggers? mini-cell, Modified cutting board plastic, etc? 8)
Thanks!
C1Dub
Hip Pads
Post by C1Dub »
PAC,
I'm currently working on hip pads for my Fanatic. Since I can't paddle I thought I'd upgrade my outfitting.
I spent time looking at a lot of different setups this year for hip pads in glass boats. I've seen cutting board braces with foam, glass/kevlar with foam and straight minicell in different widths. I think the cutting board or glass/kevlar might be the most secure.
I'm currently working on an all minicell version right now, mainly cause I have more minicell to work with than other materials laying about.
I cut the minicell in an L shape the width I wanted for my hips. The longer part will go under the deck. The short part sticks up for the hip pads. I used dragon skin to shape a bit of groove in the corner of the L to stick around the cockpit rim. Currently I'm shaping more before I glue in then I will shape the top that sticks up to allow the spray skirt to go on better.
I've talked to people that said this version will work as long as the L shape is not to thin that it breaks off from getting in and out.
If using a cutting board or glass/kevlar method you must shape the top part that sticks up carefully so that it doesn't wear through a sprayskirt.
Good luck,
Happy paddling,
Natalie
