Has anyone tried welding a Taureau?
We have material from a hatch cutout, so that's not a problem. I just wondered if anyone has tried welding that material (T-Form Elite).
Waiting to hear back from Esquif regarding this, but though I'd ask here as well.
Thanks-
Welding a Taureau
Welding a Taureau
Adam Trunnell
I have welded two of the older ones. I wasn't even goin to weld one, just heated one up to get a dent out and saw that the plastic was gettin hot enought to weld so I went ahead and welded the crack as well. I found it to be as easy of a plastic as any I had ever welded. I have not tried to weld one out of the higher temp plastic that Esquif went to in an effort to get the two half of the boat to bond better.
