alternative to a conventional pump
Just saw one of these *link* on woot.com (woot-off today).
This could be an alternative to a conventional pump. After swamping or rolling, just switch this on and let it float around spraying the water out until your boat is dry. You could tether it in if you were afraid it would get away.
That's a lot cheaper than an Attwood pump, switch, and sealed lead acid battery, too.
- monstertruckfred
Pump altenative
Scott
Looks interesting, but since there are no flow rates or other technical information posted can you post some video of yours in action. What color goes with yellow Mohawk hull?
It's a Howler!
- sdbrassfield
- Supporting Paddler
Agitation helps clarify. The water, I mean.sdbrassfield wrote:
PS: I think that Broam guy is a trouble maker...
- sdbrassfield
