Bootie Drying
Bootie Drying
Lets hear some ideas on bootie drying. Not the one you're born with...the ones you wear boating.
Paddle More.
Georeference less.
Paddle More.
Georeference less.
I usually just toss mine out in the sun... They also have some holes in them which I'm sure helps. As long as they are in a place with some airflow, they should be good to go. Make sure you don't forget em in some kind of gear bag.... I have a friend who I make put his boots in the back of the truck when we go boating simply because of the smell. ![:o](./images/smilies/icon_eek.gif)
-Anthony
I thought I had pix in my gallery, but no... I took some (abt a dozen) 18" pieces of 1" pvc and zip tied them vertically in a milk crate. This is set on top of a box fan laying on its side on top up off the floor (another milk crate would be great). I use this to dry booties, gloves, pogies, hats, etc.
Forgot about putting them under the hood of the truck - makes them warm and dry for the next day. Learned that trick from some old timers who did that with wet suits. I have some straps/buckles to keep them in place on the side of the ammo can with my tire tools:
I put them in the drier this weekend with the wet suit on delicate low heat my wife didn't like it but I could not hear it so I didn't didn't see the problem ![:lol:](./images/smilies/icon_lol.gif)
- Georgia Stu
http://i616.photobucket.com/albums/tt24 ... _dryer.jpg
Here's a little something I threw together for ALF 2010, using some 1" PVC pipe and fittings I had laying around. The flex tubing was left over from a bilge pump project, connected to a travel hair dryer. I made a duct tape boot to connect the two, with the smooth side of the duct tape on both the inside and outside of the boot to keep it from getting all goopy. Still, the hair dryer had to be used on the cool setting to keep the duct tape from getting gloppy. Next time I'll try to find something better to use for this. It could easily be made cheaper by not using the 45s or the couplings on the ends of the tubes (done only to keep from snagging booties or socks on the rough PVC ends).
It worked GREAT, but a mite noisy b/c of this hair dryer. None of the fittings are glued, so it's easy to take apart OR expand. However, the more outlets, the less air to each one. My kids (rolling their eyes, of course) said it looks like a tarantula.
when i put the boat away (store it at a shop in the corner) i hang the booties on the top of my saddle ... or i just throw them on the back deck and let the sun bake them dry
SG86
I used to put a drop or two of Dr. Botulism's (?) liquid castile soap in each bootie just before donning them. It did make them a bit squirmy underfoot at first, but the soap and the water entering the booties got the sweat out, and the booties didn't get smelly.
Maybe a few drops of Tabasco would keep your feet warm and kill the bacteria too.
As using neoprene socks, it's easy to turn inside out to let dry on their own
and find when coupled with some sort of wet-wearable shoe, gives better traction and support than a wetsuit bootie.
Occasionally I slide each one (one at a time) on tailpipe, while engine is running to fumigate, as I belive this will kill anything attempting to thrive there... and a steamy warm booty, really works wonders on icy cold days.
When unpacking from a trip I take my booties to the basement along with the damp towels, polypropolene and fleece. The latter goes in the washer & then the dryer, while the booties get placed on top of the furnace with a foot-long piece of wooden dowel or molding shoved in each to keep them open to the air. Our small furnace runs year-round as the heat source for our hot water-on demand system so after sitting on top for 2-3 days the booties are dry and toasty.
NOTE: Placement on top of a radiator or hot air vent would work just as well - perhaps even better given how well insulated our furnace is - but would have other, less desireable olfactory consequences, perhaps resulting in divorce.
