Bliss-stick RAD 185 C1 $175 obo
OC1er
Post by OC1er »
Outfitted with dashboard type bulkhead and velcro lap belt. Currently leaks thru a 1.5" long split in the vertical part of the cockpit combing, looks weldable though. I also had to rig some gaskets to stop leakage at the screw holes around the cockpit. Sounds great, huh? :D The main hull is in pretty good shape, I'll send some pics if you're interested! Boat is in SW Va (near Bristol), i'll drive 50 miles to meet.
