Nev-a-ful
Nev-a-ful
This was an idea preserved by: James Weir - who got it from - Pete Orton. I saw this at Augsburg Worlds in 95, along w/Frankie Hubbard. This version sports a foam bottom which was Homies idea...
This will link to a set of captioned photos: http://www.facebook.com/album.php?aid=1 ... 7c59456638
You can cursor over for comments, or right click to enlarge.
For particulars - I followed Jame's lead: http://blog.jamesweir.net/2010/05/nevaf ... travo.html
Hope to get it wet tomorrow!
I'm sure air bags were pooh poohed at first, too. And as somebody who has surfed a sit-on-top in a hole recently (that was LOL fun), I'm watching with interest...
Jame's says good - real good...
Just guessing it perform in holes for sure. I'm hoping it might be the ticket for continuous steep, and my goto boat for box-canyons? Could see this being real good in situations like between The Gorilla -n- Speed trap.
Yeah - we joked about it being a sit-on-top, but at least it's not a steam-powered - mechanized - or 'lectric motorized pump. Do have a couple ideas, about one way valves. But wanted to see what this did first. Of course for those with pumps, they might get by with something a bit smaller and lighter. And battery life might go way up, if it's doesn't have to run too often? Maybe not?
Hey Phil,
Cool beans I hope you have as much fun as I am having with the holes. I have written a bit more about them here
http://blog.jamesweir.net/2010/06/still ... ty-of.html
And to answer the question about whether it is a canoe or not...
I don't give a dam, it is a whole load of fun, more fun than it was before.
staying NevaFull
James
staying NevaFull
James
What's in the cooler?
I like this idea for playboating and for as Phil & James have said... long continous sections of gnarly water where dumpin' & pumpin' aren't in the cards. Can't say I'd do it to a perfectly good hull... but I'd try it with an old beat up one in a heartbeat. I think it will work even better with scuppers.
...and if it doesnt work (knowing james I dont think he would suggest, nor do something like that tho) there is still the g/flex option (my new friend, can you guess?) to re-wall sans welding ;D
(I guess it'll work tho)
And else: Even more holes than just one big at the top, now that makes an impressive canoe.. especially for our buttboatin' friends
Jan
Jan
I don't understand what you mean by that, with the holes in the boat there is LESS water in it than without them. Of course it handles better because you don't have to drive a bathtub full of water through the rapids.It looks like it would work great, as long as the boat handles well with that level of water in it.
I think I should clear this up, drilling holes in the side of the canoe means you have less water in the boat not more.
James, just back from a storming blast down my home run, and didn't have to dump once!
I mean that if a boat handles like crap with 4" or water in it, it is going to handle like crap with 4" of water in it with the holes drilled through the sides. I don't know personally how that boat handles with a few inches of water, or how it handles with a few inches more, or a few inches less.
I'm not opposed to the idea, just saying that even if it works great in your particular boat, it may not work in every boat. I have all ideas it would in this boat, but you won't know until it's on the water.
I think the holes work very well in a short OC that has a fully foamed out cockpit with bulkhead outfitting and that holds very little water, like a Spanish Fly, Taureau, Prelude and such. I would not really want to try this in a bigger boat like an Ocoee, Outrage, Spark or such, as they would, even with only 4" of water, still be very ungainly to maneuver. I don 't think I'll try this myself though, for box canyobns and other places where dumping are not an option I have a C1.
TGG!
TGG!
