Pumps?
Pumps?
How well do pumps work? I have always assumed that they were only for flatwater and mild rapids, but it seems like you all have them outfitted. I've paddled big water like the New Gorge, Upper G, and the lower 5 of the NF of the Payette without too much trouble, but if I don't play the rapids right, I often fill up completely, which has caused many unnecessary swims. Do they work well?
A caveat - I'm not an open boater. But my experience paddling with folks with pumps (even 2) is yes, they do work well. You'll still need good technique, but its far easier than having to pull off and dump...or if you are not able to continue getting more water in.
Check out James and Phil's post around holes in boats... (Nevaful) - depending on what you paddle, and if you have an old boat to try it on, might be interesting...
- horizongfx
All Pumped out
My Pump Makes me lazy.
It make hit waves head on and take on water.
It makes me miss LOOKing for the "Dry Lines".
It makes me Miss looking for a rock to get out on to empty my boat in the middle of a rapid.
It makes me miss picking my boat up more than Twice on a river trip.
It makes Me miss dumping between each ender.
It makes me miss dumping after every combat roll.
I have missed a lot in life But dumping water out of my boat ain't one of um !!!!
...........O
......(___|/____)
...........O
......(___|/____)
