Bowstall
Judd
Post by Judd »
When I initiate with a cross draw, I find that I end up with a lot of twisting momentum, and the boat almost goes into a pirouette. I think I probably need more of a sweeping motion to setup for cartwheeling, just haven't been in the pool enough to fool around and try it.
Judd
Steffen
Grüße aus der Heimat
Post by Steffen »
Hi Jan
Was hilft um immer atmen zu können ist das Paddel soweit wie möglich weg von Dir auf´s Wasser zu legen. Da hast du einen längeren "Hebel"weg um zu balancieren. Hatte das gleiche "abnoe"-Problem. Also auf´n Bug und arme ganz ausstrecken. Ansonsten viel Spaß.
Gruß
Steffen
Raphael
Ebenfalls Grüße aus der Heimat
Post by Raphael »
Hi Jan und Steffen,
was zum Teufel ist ein Bowstall???? Mein Paddel-Englisch ist ja inzwischen ganz ordentlich. Aber da komm ich nicht mehr mit.... :evil:
Übrigens Jan, die ersten Rollen funktionieren. War ein paar Wochen Arbeit und einige Telefonate mit Heinz, aber immerhin!
Grüße übern Teich aus dem Dreiländereck,
Raphael
Sorry for our german intermezzo! :lol:
Guest
Post by Guest »
Howdy,
Steffen, I actually boosted the bowstall time quite bit now. Thanks for the tip(p), will try it next Fri.
Yesterday, I was bowstalling down the Cowichan river until I hit a rock and flipped over. Could't do a screw up, it was way to fast :-)
Raphael,
a bow stall is a flatwater move where you balance your boat vertical on the bow. You can do the same on the stern, looking at the sky.
If youre really smooth, you can do a slo-mo cartwheel: go into a bow stall, then chuck another end, stay in a stern stall then chuck another end.... I am working on that.
Good to hear you got that roll to work!
On the river, Jan
Alden
stalls
Post by Alden »
I was very surprised, but it's actually not that much harder to stall with a canoe paddle than with a kayak paddle. I must admit I had a hard time doing it with either type of blade until I got the Groove (a longer, very slicy squirt boat) but now it's not that hard. I think having a lap belt may help too
Alden
Jan_dettmer
Post by Jan_dettmer »
Hi Alden,
yera, I thiml youre right. Last Friday, I could stall for as long as I wanted. With Steffgens secret german tip, I even managed to get enough air :-)
I need a spud boat because I can pump up my delirious but don't get the loop to work... Yea, I think I start shopping for one :-)
Now working on the stern stall. I only hold that one for a few secs.
On the river, Jan
Cone Bone
German lesson
Post by Cone Bone »
Jan,
I'll bite - what's the tip?
Jan_dettmer
...it's just stretching your arms so they are far enough forward. Like that you can easily get your head above the water (at least in my boat), take a couple breaths and go back to business under water.
So I have the paddle somewhere close to my tummy to spin the boat or to pump it up and i stretch them out if I want to take a breath.
On the river, Jan
