Wes Gentry & John Wood - Steele's Creek (NC) 2010
Some fun canoeyoneering pictures from today. This was a possible first open boat descent of upper Steel's Creek north of Morganton, NC. Anyone have any info on the history of boating on upper Steel's Creek?
Also happened to coincide with a first descent of Linville Falls by a K1 boater named Pat Keller. A lot of good boating going today in the Linville Gorge area!
click here to check out the Flickr album of the day.
photo credits D.H. Bathon
Wes Gentry once rolled a tandem. With me in it. The end.
yo
check the video http://vimeo.com/14434443
P.S. the gunnel grabber is there to make sure you don't drop the 50 footer
Will dance for rain
Hah... that's a technique we use as well in certain circumstances. Just funny to spot it in the pictures.driftwood wrote:yo
On one particular section of the Silver the trick is... the lead boat had better make the eddy.
One time (same river at flood above a really ugly drop/hole) I was clinging to a cedar root for dear life... literally praying it didn't break... apparently the eddy you want to be in was on the opposite side... that was a long day.
What's this run look like with more water in it... and what does that big slide run into?
Craig
At higher water it is serious class V, the eddies above the big drops are probably tiny. There are 100 yard long "rapids" that are giant sieves. I know it is run by some kayakers but I am not sure what goes and what does not.
If you are referring to the slide in the video it stuffs under an under cut, at big flows it may be ok if you can get far right.
If you are talking about the one in the pics that we repelled it drops into a deep pool that is about 8 feet across.
J. wood
and no Wes and Wayne are not related
J. wood
Will dance for rain
- FullGnarlzOC
real nice. would u go back with more water? that sieve looks runnable? ahaha
http://www.gnarlzoutdoors.com
Email: tom@gnarlzoutdoors.com
