So I picked up an XL13 for free the other day that has a pretty good crack all the way through on one side of the bow and a spot on the stern where the outer layers of vinyl are gone and the foam is exposed.
I was told normal a special type of resin is needed to adhere to the royalex, but cant seem to find what it is. Anyone know what kind is best?
Also, how does G-flex work for this kind of application?
I'll try to post a couple photos of the damage tomorrow.
Thanks for any expertise.
Repair Resin for Royalex
-Anthony
I've had good luck using Rec Repair patches and their skid plate material for repairs. The patches have their own bomber adhesive. The skid plate you can form with heat and glue down with g/flex. I highly recommend that solution.
The Rec Repair patch I put on the part of the chine of one hull has taken numerous hits and stayed put.
I would use a kevlar skid plate kit for the stern. Follow the directions closely and it will work fine. I use West system Epoxy for most royalex repairs. I think the key to good adhesion is a)cleaning the royalex thoroughly and then using acetone LIGHTLY to remove any chemical , oil or other substances , b)rough sanding(80 grit) the royalex to scrape it enough for grip,c) applying the epoxy to the patching material and letting it dry . I stretch plastic wrap across the patch and tape it down tightly around the perimeter. Remove air bubbles by use of a squegee. This will make the repair smooth.
Perhaps the hull crack could be resolved in the same way by patching it on both sides -depends on the size and placement.
Vann Evans
Vann Evans
