tools for applying vynabond
oopsiflipped
Post by oopsiflipped »
i don't have much use for vynabond, but MEK is bad, bad, bad stuff. avoid it whenever possible. you can use acetone instead for most prep applications like cleaning hull etc. +1 vote for little pieces of minicell. they do a great job getting thin layers of weldwood for foam, so i would figure also good for vynabond or anything else.
milkman
Post by milkman »
I buy Vyna Bond at a local rafting store. I just looked on the web and you can buy it easily in a can from lots of sources. See http://garage-toys.com/vybovire.html for example.
sdbrassfield
Supporting Paddler
Post by sdbrassfield »
oopsiflipped wrote:i don't have much use for vynabond, but MEK is bad, bad, bad stuff. avoid it whenever possible. you can use acetone instead ...
Don't bathe in it. It works better for gluing in outfitting than acetone. Acetone is only bad, bad stuff...
SYOTR
