My L'Edge
funkidreadz
My L'Edge
Post by funkidreadz »
My first impressions of Craig's new girlfriend. I'm not into cheating on my mates BUT..
-http://blog.jamesweir.net/2010/10/ledge ... on-in.html
Paddle safe and see you in Mexico
James
Todhunter
Ridge Spirit Outfitting
Post by Todhunter »
Nice write-up, James. So when are you going to drill holes in the side of it? :o :lol:
funkidreadz
I kinda said to Craig I wouldn't be drilling holes...So far I can't get enough water in the L'Edge to warrant holes being drilled, the dam thing just doesn't take on water!
Who knows maybe I will maybe I won't but if I do you will be the the first to hear about it here.
Today we got the first snow outside my house, I am so looking forward to Mexico in 2weeks!
Paddle safe
James
Craig Smerda
L'Edge Designer
Post by Craig Smerda »
funkidreadz wrote:I kinda said to Craig I wouldn't be drilling holes...So far I can't get enough water in the L'Edge to warrant holes being drilled, the dam thing just doesn't take on water!
sure it does... you just aren't trying hard enough :lol:
bushpaddler
Post by bushpaddler »
...as soon as the creeks in the alps fill with water in spring I'm sure it will...
Gord
saddle position?
Post by Gord »
James,
You mentioned moving the saddle forward to balance the boat for you.
Can you elaborate o how you determined this? I have a L'Edge coming shortly and have no experience adjusting bulkhead outfitting.
Gord
funkidreadz
@Gord, during my first home run, 10km class 2-3, i kinda had the feeling that the front of the canoe was being pushed around a bit too much when punching through wave trains and hydraulics. I deducted this is because the centre of balance was too far back, just like with trimming a canoe for a head wind.
So I shaved out a tiny bit more foam from the bulkheads like this
and glued a nearly 2cm piece of foam onto the back of the seat.
On my second home run I was much happier so I think I was right.
Lots of Esquif canoes are trimmed stern heavy and I change most of them, the SpanshFly is also very stern heavy, I turned the saddle 180degrees and found it much better balanced for me!
@Craig and Flo, yeah yeah I know and maybe in Spring the first Emmental L'Edge will be made!
Paddle safe
James
funkidreadz
Here is a foto of the rope handles I retro fitted, it makes the L'Edge much easier to lift about
James
dwd58
Post by dwd58 »
james, what is that you are using to shave the foam with ?
Todhunter
Post by Todhunter »
dwd58 wrote:james, what is that you are using to shave the foam with ?
He mentioned it on his blog, it is a round thing (empty gas canister) with some sandpaper glued to it.
mahyongg
Post by mahyongg »
You could also get away with a cardboard roll.. those where they ship posters in.. its longer and thus easier to grip but still sturdy ;D
cbates
L'edge
Post by cbates »
James...how did you attach your lap belt in the L'edge?
bushpaddler
Re: L'edge
cbates wrote:James...how did you attach your lap belt in the L'edge?
I case James is aleady on the way to Mexico, here's how it works. Nice and easy solution...
http://blog.jamesweir.net/2009/11/pimp- ... white.html
Florian
