CHOICES-PLAYBOAT CONVERSION
HEY,
Looking for some ideas for a playboat conversions from k-1 to c-1. I am a 225# paddler looking to do some river play/freestyle moves.
Thinking to start a winter project and just want some feedback on some personal boats that worked out well. I will check past posts also, but I was leaning toward some of the newer boats out there.
HELP!?&THANKS...HH
HELP!?&THANKS...HH
I am 225 lbs
I find my Project 62 works well for play.
- Smurfwarrior
- kiwic1chick
If you've got the money, go for one of the 2010 Jackson star series - I use the All-Star but I'm quite a bit lighter than you (147lb.) It's an awesome boat, way faster than what you'd expect for the length and super smooth. I almost had it cartwheeling in the pool before I converted it - this is kneeling on the k1 seat with no form of straps or outfitting. Personally, I think it makes a better c1 than k1. I'd suggest you look at the Mon-Star, as with these boats you're better off being at the lower end of the weight range rather than the upper.
Any girl can be glamorous. All you have to do is stand still and look stupid. I choose to go paddling.
hammerhead wrote:I am looking to do mostly; flat spins, bow stalls & enders. HHTheKrikkitWars wrote:What do you want to do in it? Moves wise that is?
A wavesport Z may be a good choice if you aren't looking to do a ton of the newer moves. I'm not big enough (165) to get bow stalls in one, but enders and spins are usually not a problem.
I'll throw in another vote for the jackson star series if you can swing it. Even the Fun series would make a killer c1 if you aren't looking for the highest octane of playboating. Both are also capable river runners. Definitely pick the one in which you are more towards the low end of the weight range unless you want to sacrifice some stability/comfort in the name of really being able to throw it around for cartwheels and other moves.
-Anthony
- kiwic1chick
A slightly too small boat won't give you a lot of extra throw-around-ability, just extra twitchiness. I paddled a RAD 185 c1 for quite a while, this was 2 whole boat sizes too big for me, but I was still able to flatwater clean cartwheel it. They were pretty low angle cartwheels, but this boat is only one gallon less than my creeker!
My point being, it's easier for a canoeist to throw around a boat that's too big than a kayaker.
- Smurfwarrior
- marclamenace
