NRS creek gloves
NRS creek gloves
Are 2mm neoprene with synthetic palm and carbon/kevlar on the knuckles. They are comfortable to wear and don't fatigue the fingers after prolonged use. They are not as warm as pogies.
Although a little pricey at $75 my very worn down knuckles are worth it.
Check it out at NRS website!
Pogies
I have used pogies for many years and appreciate the warmth factor. The gloves on the other hand allow creekers to release the paddle to push off obstructions and regain paddle control without dealing with a dangling pogie.
I'm using NRS mittens
I don't like pogies because of the hands-free issue and I find neoprene gloves still cold. This year I bought neoprene mittems from NRS and they are very warm, way more comfortable than gloves, and provide excellent paddle grip / control. The cost was around $30-40.
C1 Throwdown--Ride'm Cowboy!
I paddled the first time with the creek gloves this weekend.
This is what i think of them:
They are pretty good! However, they are designed for kayakers. I found that my thumb (shaft hand) gets whacked most of the times when I bounce off rocks or go down narrow slides. it would be great to have more protection for the thumb. I think I will add some foam.
The gloves are not warm enough for winter paddling here in BC but are fine in the spring and fall. Paddle control is excellent. It is almost unnecessary to use paddle wax.
For low volume creeking they are excellent. On other stuff they seem to be overkill...
Cheers, Jan
Cheers, Jan
- Bruce Farrenkopf
Creek gloves
I just contacted NRS about the thumb knuckle being compromised and was told that it would be brought to the attention of R&D and I would be informed as to the decision of including a thumb knuckle protector.
I told them that this was a pretty important issue for me due to the fact that I lost knuckle skin creekin' this weekend with the gloves on.
The good news is that the rest of the hand was well protected.
- Bruce Farrenkopf
The NRS Creek Gloves arrived in the mail on Friday and I noticed that the pair I received DOES have a thumb knuckle guard . I checked out the creek gloves for the first time this weekend on Pauley Creek, a steep, low volume, technical creek draining into the North Fork Yuba. On the river they were comfortable and allowed me to have a solid grip on the shaft and T-grip of the paddle. If I hit anything on the river with my hands I couldn't tell. That's a good thing. I like the way they cover and protect my wrist as well. The gloves were also warm under the circumstances, cold water (35 F) and warm air temp (75 F).
I'm not sure how well they will wear. The palm side of the gloves will be the major wear area if they are similar in this respect to the NRS Paddlers Gloves I have been using in the past. If that's the case, I'll be replacing them every 2 years at $75 a pop instead of $35 for Paddler Gloves. It may be worth it.
SYOTR,
Bruce
SYOTR,
Bruce
