Life as paddler stinks once in a while...
Like for me right now , ran Beaver Creek in Marmora Ontario yesterday, was slightly right off THE line at the bridge drop, my bow got hung up on shore on river right. I flipped downstream and went over 2 ledges (in about 3 - 4 inches of water) upside down, with my left shoulder taking the majority of the hits .
Tried to roll in the pool above the next drop, , felt fairly intense pain in my left shoulder and no resistyance on the paddle whatsoever. Bailed out and made it to shore just in time to avoid the next drop.
Result: broken shoulder blade (will, according to the doctor, put me out for at least 6 weeks), cracked my composite helmet, broke my paddle and tore my drysuit ...
Thanks for the guys who were there to help me !
martin
martin
- Bruce Farrenkopf
boatin
oh man martin, im really sorry to hear that. this year has really been one for injuries. of my paddling friends -- already this Spring one got stitches, one got a huge black eye, another popped out his shoulder again, and a woman from Vermont tragically drowned in a sieve this weekend. Glad to hear you're OK.
Be careful out there -- there is bad karma in the wind this year . . .
Alden
Alden
Repairing a ripped drysuit: $85.
Finding a new blade for the Werner carbon shaft: $160
Crack in the (indestructible) Galasport composite helmet: $250
Knowing that Martin Breau will eventually be back on the river with a huge smile on his face: Priceless
Martin, Since I know you, I took the liberty of trying to make you smile… Hope it lifted your spirits somewhat.
I'm really sorry to hear about the mishap. Hopefully things heal up fast. Glad you didn't swim the second drop.
Hang in there!
Glenn
Hang in there!
Glenn
Glad to hear the your helmet and not your head took the hit. Thanks for keeping us informed. Time to start dreaming about what to do once you are back on the water and concentrate on a good recovery. Do push it till your fully recovered. Wish you good luck on the recovery.
Harsh Tale!
Ouch!
Glad you are on the mend. Good luck with your recovery.
Cone Bone
randy@artisansgroup.com
Thanks to all you guys for your support !
Natalie, I hope your surgery goes well and you recover quickly!
I actually consider myself lucky, I think considering what happened, the consequences could have been worse...
I learned a few things though, like consider the consequnces really well of any drop you run and, if you run shallow drops with sharp rocks, wear the best protection you can.
I tink I did a good job on head protection (Galasport extreme full cut composite helmet with a Cascade face cage), but I failed to adequately protect my upper body for the conditions I paddled in.
I will definitely get myself some body armour to protect my chest, back, shoulders and arms. I will also upgrade to th armoured creeking gloves. I realize that there is no absolute protection, but after this experience, I do definitely want to upgrade.
Do any of you guys wear body armour when creeking and, if yes, what?
martin
martin
Martin,
hope you recover soon!
I wear elbow pads like the ones Alden mentioned. They cover elbows and lower arm. I also bought the creeking gloves.
I am thinking of one of those shirts that combine Shoulder protectors and Arm protectors. The rest is covered in the PFD. I whacked my shoulder once and it sucked.
There is a PFD from Hydroscapes in Golden that has Body Armor for kidneys and neck and shoulders. It might be the best creeking PFD out there but is also expensive.
Cheers, Jan
Cheers, Jan
Bummer...
Martin
Major bummer.....
Hope you heal quickly!
Helmets are cheap compared to the alternative - glad to hear you at least had enough protection for your head! Being positive about it!
Major bummer.....
Healing and body armour
Martin,
Wishing you a speedy recovery. Regarding the body armour, you may want to consider rugby shoulder pads. They cover the upper portion of the chest and back, and may be less intrusive than the biking body armour I've seen some people wearing on the river.
BTW, I'll call you about your Atom next week.
Geoff
Geoff
Body armour
Can be a detriment if overdone. It can in fact cause a capsize due to restriction. Some of the previous posts are right on with the head gear and elbow pads. One other item that I use is the Wavesport drytop that has removable elbow pads, and sewn in shoulder pads.
Good luck on your recovery.
