Another thwart lenth question
I was reading the thread on thwart lenth tinkering and was wondering if it would work for my spark. Looking for more stability being a newbie with out getting a different boat. Any thoughts?
thanks
chris
thanks
chris
Hopefully Kaz will weigh in on this... but from what I've learned I'd suggest that you do not pull in the center thwarts unless you want it to become more unstable. I do believe John pulls in the most rearward thwarts just a touch to make it a bit drier in the stern but the amount he pulls them in I am uncertain of.
Kaz is doing a few "clinics" this year... maybe taking one is something worth considering if you want to maximize your personal performance in that particular boat. It's a go-fast hot-rod if you know how to use it properly.
I wouldn't pull the middle thwarts in, on the Spark, unless you're having a hard time reaching out with your forward stroke.
What I did to my Spark is remove the rear wood deck, take out the last 2 rear thwarts and push the hull out as much as you comfortably can, then cut new thwarts to fit the wider hull. You can re-use one of the thwarts you pull out. If you do this, it will make a boat a little bit drier(in theory). Also, the little wood deck won't fit back on.
JKaz
JKaz
Seat height?
As you say, trying slightly longer thwarts can't hurt.
But, seat height is a sure way to firm up a boat. Is yours as low as you can possibly tolerate? I would think someone with a Spark and stability problems would want a seat <7" high.
Roy
Roy
Hip Blocks
Oh yes, one other thing. Do you have hip blocks? Are they tight fitting?
Snug hip blocks make a world of difference in the boat-stability department.
Roy
Roy
- Smurfwarrior
I recently paddled an Esquif Prelude. It's a great improvement on Pyranha' version.
The hull was flatter, the chines harder and I"m certain the thwarts were longer. I reshaped my Pyranha to give it an equally flat bottom and significantly harder chines.
The Esquif was ten times better than the stock Pyranha and also had noticeably better initial stability than my modified, with no perceivable difference to secondary stability.
Appears to me that even small adjustments to thwart lengths can make big differences.
add- I couldn't tell any difference in speed or tracking, it did seem a little bit more manoeverable than my boat, but I can't say this was due to thwart length affecting rocker or having rounder more forgiving chines
