Best to Seal Switch for Bilge Pump?
- fleckbass
What is best to seal the switch for Bilge Pump. I used a big gob of Silicone in the past. What have others found to work well?
- horizongfx
The Very Best I found thus Far
Not the Cheapest, But The Most reliable I found thus Far.
And the One I use in all My Pump set-ups.
https://www.alliedelec.com/search/produ ... KU=8261003
...........O
......(___|/____)
...........O
......(___|/____)
- sdbrassfield
- Supporting Paddler
- marclamenace
- Smurfwarrior
I second the .99 cent light switch from home depot. Fancy $10-20 waterproof switches dont last long. a cheap light switch has solid connections and will last a long time. I dont even waterproof any of the connections in any of my boats unless you're using lithium batteries. keep them dry.
if you get the light switch. take a pair of pliers and bend the ears a few time to break them off. These switches aren't bulky at all.
Team Blackfly
- Jim Michaud
I've even had a Marine waterproof switch fail on me. Now I go to Ace hardware and buy a regular toggle switch and a bottle of Re-Rack. Re-Rack is the stuff that is used to repair dishwasher racks when the coating starts to wear off. The bottle has a little brush connected inside the cap. I give the switch lots of layers of Re-Rack. I haven't had a bad switch since.
Jim
Jim
THinking about batteries and switches again, I searched the forum and came up with these :
http://www.batteryspace.com/component-s ... ector.aspx
that would go with these...
http://www.batteryspace.com/waterbottle ... eplug.aspx
http://www.batteryspace.com/connectorad ... lcord.aspx
Hmmm...
Hmmm...
- horizongfx
Waterproof
Not sure how waterproof That Bottle is !, I can tell you from My experience that those Poly-switches and PCB's that are mounted to the Batteries via a Circuit board Absolutely cannot get wet.
...........O
......(___|/____)
...........O
......(___|/____)
- fleckbass
