I'm looking at a 2006 Subaru Impreza wagon with factory roof rack. Has anyone tried to supplement/modify/replace these with Yakima? What pieces do you need?
Thanks mates
Aargh!
Racks and Subarus
i've got a 2004 outback with factory racks. i put my yakima bars and towers on that also. last weekend i had a tandem canoe and two c1's on it. works great!
- jatakasawa
I made some bomber homemade racks for my Subaru using 1/4 steel cable and the nut/clamps for them and some painted steel cross bars. I drilled holes through the cross bars that lined up with the factory Subaru rails. (The holes are on either side of the rails.)
I then fed the coated steel cable down through the cross bars, around the factory racks and back up through the cross bars and then put a nut/clamp on each cable. I made two more connections to the factory cross-bars and was in business. The whole thing cost me about 35 bucks and I lugged three boats down to ALF (ten hour drive) using them. Bomber.
My digital camera is down or else I'd send you pictures.
Chester the Brace Monkey.
