Racks and Subarus
aargh
Racks and Subarus
Post by aargh »
I'm looking at a 2006 Subaru Impreza wagon with factory roof rack. Has anyone tried to supplement/modify/replace these with Yakima? What pieces do you need?
Thanks mates
Aargh!
lagow8
Post by lagow8 »
I have 68 inch yakima cross bars on my 2002 forester. Fits 5 boats (c-1) with the yakima stacker. The bars connect to the side rails where the factory bars fit. Its a bit expensive, but worth it.
you need to get a fit kit that matches your car model.
coloradopaddler
Post by coloradopaddler »
i've got a 2004 outback with factory racks. i put my yakima bars and towers on that also. last weekend i had a tandem canoe and two c1's on it. works great!
craig
Post by craig »
Older models are easy to add cross bars, you just need the yakima/thule adapters. the 2010 models are going to take some serious modification to hold just 2 full size open boats I think the load capacity is about 100lbs, not enough for 2 boats
jatakasawa
Post by jatakasawa »
I made some bomber homemade racks for my Subaru using 1/4 steel cable and the nut/clamps for them and some painted steel cross bars. I drilled holes through the cross bars that lined up with the factory Subaru rails. (The holes are on either side of the rails.)
I then fed the coated steel cable down through the cross bars, around the factory racks and back up through the cross bars and then put a nut/clamp on each cable. I made two more connections to the factory cross-bars and was in business. The whole thing cost me about 35 bucks and I lugged three boats down to ALF (ten hour drive) using them. Bomber.
My digital camera is down or else I'd send you pictures.
Chester the Brace Monkey.
Roger
Post by Roger »
Got a 2006 Outback and the Yakima mounts for the factory rails fit perfectly along with the 68" bar. Put stackers on them.
Pricey but perfect and solid.
