Going upside down over cascades in OC-1
I'll go out on a limb and define fun as not headboofing a class V slide/cascade...Craig Smerda wrote:Please define "fun" for us older and more experienced folks.FullGnarlzOC wrote:With that being said, it's less likely I would have flipped in a L'edge yes - but then I'm in a boat that is not near as fun to paddle the other 98% of the time.
-Anthony
- Jim Michaud
- FullGnarlzOC
Thanks Jim.
Good news is...my form going over drops upside down is great. It's being confirmed. I was thinkin I might have to switch it up and learn to take the impact another way...but seems that I'm takin the hits how i should...as I should be doing at this point
And to define "fun" for you "older folks" - I spend over 60% of my time on the water on class II-IV runs, helping others progress, get out there, and push themselves. The Maxim is great fun on any kind of rapid - I know I can take it whereever and have a great time on the water. If it's a smallish II-III type of rapid, I can take advantage of subtle water features and zoom in and out of moves throughout the creek. On IV-V - using the water w/ an advanced boat translates to HUGE REWARDS for me personally - as I continue to get better as a paddler and w/ the boat...
Orrrrr - I can just get in a L'edge and style everything, all the time - but wut 'fun' is that
PS - If you guys didnt notice - I rocked the rest of the run. And completely styled the same drop that I screwed up - and that's my first real 'vertical' run in the Maxim and 2nd run of that creek. How do you think it goes my 10th run?
http://www.gnarlzoutdoors.com
Email: tom@gnarlzoutdoors.com
- rockyboater
I took a few really hard hits to the back creeking a few years ago. After that I decided to find some sort of armour. I don't know if it's still being made but I picked up a Stohlquist creeking PFD that has kevlar armour plates on the back and sides of it. Still gives you full movement and feel the same as any other PFD. Using this with elbow pads on rocky creeks has given me the confidence to try thing I would have backed down from before.
- FullGnarlzOC
I don't know ...
I don't know much about upside downing waterfalls but...
I always cut away from my "valuables" when I am using a river knife on my canoe.
funkidreadz
Boofing and Pluggingget in a l'edge my arseee. Look - at how well that Maxim resurfaces.
Fast forward to the plugging bit,
I know I posted this just the other day in another thread, but after that comment Tommy you need to check out THE best resurfacing ever flimed.
Paddle safe,
James
- FullGnarlzOC
James - I watched that clip over and over again when you originally posted it to ur FB months ago. Then I studied the L'edges design very closely to see how the boat could have possibly resurfaced that perfectly. I was convinced that it came up like that because of the lip of the tumblehome - i figured it guided the boat in and out of the water in an 'arc' like fashion.
Either way - my thoughts are the same now as they were back then... that is the most badass 'black attack' (as Mick had called it)... that I had ever seen.
- FullGnarlzOC
Phil - I have a second thwart in front of my bulkhead(in addition to the ones that go over the back and front of the bulkhead) - It was put there to add extra bomberness - Think I should take it out? to allow for a better tuck n plug?
