if any choice, what K1 would you convert?
Hi folks,
Seeking C1 knowledge.
I paddle a prelude, which I really like. Paddle III/IV so far.
For space reason (and money too), I will not be able to take my boat back home to the Alps from Scotland...which sucks!
However, I might be able to get a K1 for cheap down there, convert it and leave it there for every summers to come (at my parents).
I do river running, would like to start creeking at some point. I'm 5ft11 and 165lb.
Please could you give me a top 10 boat list you would go for and I'll start looking for one cheap in the Alps (you don't need to justify your choice... I'll do consencus vs. availability).
Ta
Ta
Erick Baillot
I'd convert a Jefe or Jefe Grande, it took me a long time to work it out, but it does need the saddle to be lower and very slightly further back than is normal for a c1 to get best results.
Not exactly coincidentally; If you'd be able to take it with you, I have a welded Jefe shell you can have for nothing, it's currently a bare hull, but I have some ideas to make it back into a viable if ugly C1 at next to no cost (as I already have pillars salvaged from old boats).
If you want me to try and sort it out, I'll grab the shell (and some reinforcing material to make sure the weld holds) and put some pillars and grab handles back in/on; there's also a saddle (it's the one designed to accept quick-change bulkheads) from the previous convertion.
I used to have a Prijon Rockit - loved the plastic. Would be interested in seeing some current Prijon hulls. Haven't seen a *current* Prijon arounf here in forever.
I have a small Burn and a Remix 69. The Remix is much faster - I actually find myself overshooting targets (surf waves) when ferrying. The Burn has harder edges and is therefore more playful and slightly less forgiving. I'm calling the Remix my "confidence boat" and the Burn my "playful / solid boat". Both are excellent!
Only other nomination for river running is a Dagger GT(X) which is high volume, fast and surfs nicely.
I had an everest which is a burm with just a little more length. Found it to be an awesome C1, (just didnt like the hole skirt thing)
a friend jad a burn and just didnt think it was fast enough. I think the Everest solves some of that problem.
super stable, with an added Edge.
Kind of reminds me of a sleeker, faster C1 Ledge
Proud Yankee
The everest is a good boat (in my mind the best boat pyranha currently make by a loooong way...)TonyB wrote:I had an everest which is a burm with just a little more length. Found it to be an awesome C1, (just didnt like the hole skirt thing)
But it's more than just a longer burn... The major improvment is that they softened off the increadibly sharp edges (Finally), the boat is narrower than the Burn L but has more volume, resulting in a boat which has a better volume distribution and finally the rocker profile gives similar boofing characteristics to that of other creekboats, yet a longer waterline length than most of it's competitors...
It's the first of the inazone derived (well how else did you think the H2 Zone got it's name and distictive nose profile?) full size boats I can legitimately call a creekboat rather than a river runner without feeling dirty.
- marclamenace
