Outfitting question
Outfitting question
I'm helping a friend with his new L'Edge factory bulkhead saddle. I saw Craig Smerda's outfitting guide on this site and it was helpful. I like the idea of pushing pvc pipe through the saddle in three places to allow water to drain from one side to the other. I'm wondering what is the maximum diameter pipe you should use? Is three pieces the absolute max or can you get away with more? Lastly, what's the best way to file or trim the openings for your knees? Dragon skin? Should it be wrapped around some cylindrical object like a can or something?
I used 2" pipe in three places. The water transfer is almost instantaneous most of the time.
As an alternative, you could take a look at what Bob Britt does for his saddles. I think it is a single large piece of down spout that is large enough to fit a pump (in case you ever want one).
Two things I would recommend would be to shave out the thigh hooks until you "just" fit and then check the trim of the boat. If the trim is off a lot, it's easier and better imo to move the saddle a little than it is to trim more and more foam.
The second is to remove the saddle before you push the pipe through. It's waayyy easier and the saddles in PE boats never stay glued for very long anyway.
My L'edge bulkhead has the three small PVC pipe transfer tubes, however my old Beluga bulkhead had two nice big arcs cut out of the bottom that flowed water much much better. I saw a new Prelude recently with a bulkhead without these tubes. If your boat doesn't have them I would recommend doing something
I find the rasp worked the best for fast bulk foam removal, and the 60 grit finished it off nicely.
*** caution ***DougB wrote:My L'edge bulkhead has the three small PVC pipe transfer tubes, however my old Beluga bulkhead had two nice big arcs cut out of the bottom that flowed water much much better. I saw a new Prelude recently with a bulkhead without these tubes. If your boat doesn't have them I would recommend doing something
The post/pipe helps prevent a stress riser from forming in the void... seen the result in many a boat needing to be welded in the area missing/devoid of foam. Yes - theres a riser to either side of a saddle; however not near the same as one spanning or bridging a void. Were the plastic is supported on two side.. most every thing will keep poking against the non-support span. A death sentence - in the making!
