Right near the coloured phasing tape on the electrical shelf should be
3M Splicing Tape- 600 v.
Industrially it is used to cover large diameter terminations and splices.
It is rubber in texture and is stored in a roll with a layer separation flim, otherwise it will "meld" (bond to itself).
It is stretchable which helps it adhere under tension and soon "melds" together with no unraveling ends and no glue.
I use it on my paddle successfully, on the plastic T grip and the carbon fibre shaft. Lasts very well. Probably same stuff a previous post mentioned but in a industrial version.
Taping paddle shaft - you, too?
Splice tape
Re: Splice tape
I've thought about trying this on carbon shafts-
http://www.google.com/products/catalog? ... CFoQ8wIwAQ#
Comes in different colors, may even make a decent touch-up for vinyl skin boats
JD
The plastidip that you actually "DIP" things into and the stuff in the spray can are two different things in my opinion. Only tried it on a metal surface...but it came right off. In fact, i was able to peel it off in basically one big piece.
Even if you prepped the shaft with sandpaper and cleaned it with acetone I bet it would rub off after a few strokes. (Keep your mind on paddles here folks...I'll not be responsible for any trips to the E.R.)
I used the "dip" type of Plasti-Dip on the shaft before. It didn't last that long but it didn't instantly deteriorate either. I brushed on at least 5 thin layers, and if I did it again, I'd do ten layers. Probably build up 0.06"-0.08" thickness.
At any rate, I just ordered some of the recommended tape, so I'll try that first.
