I feel the need for [bleeding off some] speed.
Post by Larry Horne »
i just crash head on into a boulder. that stops me real fast and tightens my straps at the same time. :lol:
bcmcmillan
Back sweep it
Post by bcmcmillan »
What I usually do (in small pools) is a huge onside back sweep to turn the boat sideways to kill speed. After getting sideways you have options of catching an eddy or doing a full 180 for a up stream ferry. Or if your on top of the next drop a large forward sweep to get you pointed back strait for the next drop, but the back sweep will usually give you at least a second to think of the thrashing that your about to take in the next rapid!!
Brad
FullGnarlzOC
Post by FullGnarlzOC »
phil hit it - initiate a back ferry - this is also good for when u get in a cluster of boats in mid rapid and you want to get some space
http://www.gnarlzoutdoors.com
Email: tom@gnarlzoutdoors.com
TheKrikkitWars
Post by TheKrikkitWars »
Phil did indeed hit it, I'm not sure that a pure backferry would have worked but his other "not enough water" suggestions seem to be right on the money...
philcanoe
Post by philcanoe »
TheKrikkitWars wrote:Phil did indeed hit it, I'm not sure that a pure backferry would have worked but his other "not enough water" suggestions seem to be right on the money...
... from years
  • :wink:
of being out of control and shallow.
    TheKrikkitWars
    ... from years
    • :wink:
    I look forward to being able to use that line myself someday :D
