the L'edge deck semi chop
Craig Smerda
L'Edge Designer
Re: the L'edge deck semi chop
Post by Craig Smerda »
View the photo then "right click" then "print picture"... in case you kids want to get out your crayons and do some doodling before cutting... :wink:
PatrickOC1
Post by PatrickOC1 »
Craig Smerda wrote:Zach's
Thats what your boat needs buster......more cowbell... :lol: .
seriously is that a cowbell? :o
truckeeboater
Post by truckeeboater »
"Guess what? I got a fever, and the only prescription... is more cowbell!" :lol:
Peace Pow and Paddling!
philcanoe
Post by philcanoe »
just do it...
... (well) maybe that'd be overdoing it.
    busterblue
    Post by busterblue »
    This is old news, but I figured it would be nice to follow up. I had done a lot of hand-wringing over the prospect of cutting the decks off, but it turned out to be a very easy project.
    First, I traced lines with a wax crayon. I left a 2-inch lip where gunnels would normally be. (Basically, just extending the lip that is in the cockpit area). Following some wise advice on this forum, I kept the wave deflector on the front . This was to avoid smashing my hands on the chunk of plastic that would otherwise be sticking out. For the ends, I found something round to trace.
    I cut pretty far out to the ends. Originally, I had planned to add thwarts for stability, but it does not seem necessary. The remaining plastic keeps the hull quite stiff.
    Lacking power tools, I made the cut using a keyhole saw with a fine blade. This was a little bit of a pain, but it did not take long. The remaining edges were sharp, and for a while I was cutting myself on them. I finally got around to smoothing the edges with a Shureform shaver and sandpaper.
    The weight difference is negligible. But taking the decks off makes everything a little bit easier -- from storing gear to minor outfitting tweaks. It takes a little courage to make the chop, but it's not hard.
    truckeeboater
    Well done! She looks great :D
    Creeker
    Post by Creeker »
    looks nice but it might be just a bit better to put a small curve leading to the deflector vs the acute angle you cut. Just point it out maybe for the next guy. Enjoy stomping the Goods in that bad boy.
